Its a GT model, so has alcantra seats/door panels/folding mirrors and turning fogs.
IIRC the car has somewhere around 95000 miles on it.
I do have the original CT-26 that will go with the car.
I may have the OEM Dp with cat, just need to look for it.
Will also include a custom dual muffler exhaust.
Will also throw in a complete set of lowering springs--they were only on the car for a few weeks as they rode a little to rough for me.
Nearly 100% complete interior and is in good condition.
Turbo timer installed
No stereo
Blitz boost gauge installed into factory gauge cluster
Car had alot of parts replaced just prior to being taken off the road:
Brake pads and rotors all around
Timing belt/tensioner/water pump/hoses and belts
Radiator
Clutch and pressure plate
New front drop links
Replaced drivers window regulator
Car also has REV2 front lip fitted
REV3 springs/struts
Has REV 3 wheels that were refinshed prior to me purchasing them.
Body is in reasonably good shape, paint is faded from sitting, but will cleanup with some work.
Small amount of rust on drivers door silll--had this treated/painted in 2006, but the shop must not have done a good enough job.
RH headlight won't raise and lower now, I never had a problem with the lights while the car was on the road from 2006-2008.
The nutplates in the rear subframe for the control arms need to be cleaned up with a tap(which I have, cost me nearly 15 quid) also have new bolts from Toyota.
Has original tail lights installed
Dyno'd the car in 2008 at TDI.
Pics from when it was on the road--Will try and snap current pics in the next day or so.
![Image](http://i152.photobucket.com/albums/s182/86AW11/1990%20MR2%20Turbo/1990MKII146.jpg)
![Image](http://i152.photobucket.com/albums/s182/86AW11/1990%20MR2%20Turbo/1990MKII142.jpg)
![Image](http://i152.photobucket.com/albums/s182/86AW11/1990%20MR2%20Turbo/1990MKII140.jpg)
![Image](http://i152.photobucket.com/albums/s182/86AW11/1990%20MR2%20Turbo/1990MKII143.jpg)
