ST185 calipers
MarcsMR2
ST185 calipers
Post by MarcsMR2 »
Morning,
For Xmas my wife has bought me some ST185 twin pot calipers :D
Only problem is I'm not sure what other parts I'll need for the conversion.
Discs? Carriers? brake lines?
I understand it's a simple swap but would like to be sure before I jump in lol
Help and part numbers welcome :)
PW@Woodsport
Re: ST185 calipers
Post by PW@Woodsport »
You don't need anything else, they will just bolt up to the Mk1 hub and fit the Mk1b disc.
That is presuming you have the 256mm versions, they also did a 277mm version, so you would need a 277mm disc for those.I would also check exactly what you do have because to the best of my knowledge only the st165 had twin pots.... i think the 185's were all singles, but it gets complicated on the 277mm versions, they might have done a twinpot for those.
Basically if they came from a 256mm disc'd car you are good to go :thumleft:
MarcsMR2
Re: ST185 calipers
Post by MarcsMR2 »
The calipers are deffo twin pots, fitting to a mk1b (D reg).
Is there a part number on them I could look for to make sure?
PW@Woodsport
Re: ST185 calipers
Sorry i don't know.
jon_st205
Re: ST185 calipers
Post by jon_st205 »
Early import ST185 came with twin-pots. I think they're slightly different to 165's but still bolt up to your exisiting disk. However I don't think these are a big upgrade so I would flog them on and look for a set of the ST185/UK ST182 single pots. Nice thought from the missus tho :thumleft:
PW@Woodsport
Re: ST185 calipers
On the contrary jon, the twin pots are a great upgrade, that's why the heavier mk2 mr2 and celicas have them :thumleft:
jon_st205
Re: ST185 calipers
Post by jon_st205 »
Hmm, I guess, still a tiny disk would be my concern. They are very ill thought of on the ST165/ST185 though, yes, I will grant that they have an extra 300kg's to stop.
Jon
cartledge_uk
Re: ST185 calipers
Post by cartledge_uk »
My advice would be a test fit, remove one wheel and caliper (keep it connected to the brake pipe, just zip tie it out of the way making sure that the brake pipe isn't stressed) and just try the combinations of caliper and carriers.
When you have a fit you are confident with, then do the real fit.
You will need some new brake fluid if all goes well :thumleft:
MarcsMR2
Re: ST185 calipers
Post by MarcsMR2 »
Think I'll be trying that this weekend. My concern looking at them is that 1 of the carrier bolts look different.
I thought both top and bottom bolts on my existing Calipers had the same sort of hole but on these it seem different on the 2 bolt holes.... maybe I'll take a pic later and post it. :)
PW@Woodsport
Re: ST185 calipers
You do have the celica carrier brackets as well don't you?
If not they aren't going to fit i'm afraid.
MarcsMR2
Re: ST185 calipers
Post by MarcsMR2 »
only got the calipers.
Guess the first thing im gonna need to do is get the carriers then lol
Any one know the part number?
