the faster you go, the more noticeable it is.
Tracking is A+ spot on using a hawkeye lazer tracker.
For example, say im on the motorway at 60mph, give it some throttle and it pulls to the right
, not seriously badly
, but enough to feel unstable and be a bit scary.
coming off the throttle causes it to return to its normal straight.
I also notice that if i sit on the spot and move the steering 1/2 turns from left to right, i can see the front of the car follow slightly.
Ie if i turn the wheel left, the nose of the car will move an inch or so in that direction.
generally the steering feels quite sloppy.
afaik
, I have 15 year old bushings f+b and ball joints.
all bolts are tight.
Im quite sure that its either ball joint wear or
'forward/backward' movement in the bushing rubbers.
.or perhaps both?
Im quite sure the car remains straight under braking from what i can remember?
Could anyone give me an opinion?
thanks
