A new Cinquecento radiator
and thermostat switch to "block the hole off"
Just wondeing wat else I need - Ive looed Toxo's list (see below) but unsure whether any o that is already in the bits ive been given eg. water bottle etc
Is this list what else I need to by? (ive edited the list as I see fit but original can be seen here
http://www.imoc.co.uk/forums/viewtopic. ... ight=st205
1 x Coolant Bottle - T08889-80002 (have I got one already?)
2 x Bolts to bolt down CC core - T91631-60816
2 x Long Throttle Body Bolts w/washer - T90119-08870
4 x Throttle Sock Bolts - T91511-B0825
1 x Throttle Sock - T17861-88480
1 x Accel. Bracket - T78024-88480
1 x Engine Hoist Hook - T12281-88480 (requires modifying)
2 x CC Pump Bolt - T90105-10393
1 x Throttle Body Support - T17871-88480
1 x CC Expansion Tank + pipework - T16650-74020
and a load of piping
