[Mk2] [Turbo] clutch changed 2k ago but gear change at high rpm / load is difficult
raptor95GTS
Post by raptor95GTS »
as above, basically changed the clutch, std replacement jobbie from Ebay and it works fine. Nice and light but it bites like a centimetre off the floor. While I've adjusted to the feel of that, I've noticed that shifting gear at WOT is quit difficult. No crunch but the gearstick just doesn't want to move. Almost feels like I should be using two hands to move it :(
What adjustment can I do to make it easier to change gear at WOT
mark239
Re: [Mk2] [Turbo] clutch changed 2k ago but gear change at high rpm / load is difficult
Post by mark239 »
did you bleed the clutch properly
Matt_Cooper
Post by Matt_Cooper »
As said, bleed the clutch again.
raptor95GTS
will do, cheers folks :thumleft:
