Miles to a tank
dazz_ni45
Miles to a tank
Post by dazz_ni45 »
Hi everyone, picking my my new Rev 2 turbo on Friday from Stoke-on-trent for a long drive home to N Ireland via Stranraer. One issue with the car is that the fuel hand is stuck (dials recently replaced with lockwood dials) so I won't be able to tell how much fuel I have left.
So driving reasonably sensibly at motorway speeds and on A Roads how many miles should it do to a tank assuming I fill her to the throat when I am leaving.
Tiny
Re: Miles to a tank
Post by Tiny »
Id say 60-65mph should see you 30-33mpg. 300-340 to a tank full id start looking for petrol statons at about 280 though. that is basing everything on tip top fueling and ignition though
Steve-O 2007
Re: Miles to a tank
Post by Steve-O 2007 »
I only get about 150 - 160 miles to a Tank in mine. But then again I do alot of cold starts combined with short trips to work in town :(
Ryan S
Re: Miles to a tank
Post by Ryan S »
dazz_ni45 wrote:Hi everyone, picking my my new Rev 2 turbo on Friday from Stoke-on-trent for a long drive home to N Ireland via Stranraer. One issue with the car is that the fuel hand is stuck (dials recently replaced with lockwood dials) so I won't be able to tell how much fuel I have left.
about 3 months ago i managed to get from Clacton on sea( south east of london by about 90 miles) all the way to Dundee (north east Scotland)for 70 quid. and i wasn't really taking it easy.
prob about 600 miles. possibly more with the xxxx route i took.
mattcambs
Re: Miles to a tank
Post by mattcambs »
Steve-O 2007 wrote:I only get about 150 - 160 miles to a Tank in mine. But then again I do alot of cold starts combined with short trips to work in town :(
All in 1st gear? You should get better than that, surely?
On a long haul at 70mph, I got 37mpg from my rev3, which was about 320 miles from the tank. Normally get about 30mpg, which is 60% motorway driving at 70mph.
I'd have thought at least 250 miles from a full tank at a steady cruise on a rev2.
dawolf
Re: Miles to a tank
Post by dawolf »
It's not very often I fill up the tank but I'd say I get about 230-250 miles to a tank with mixed driving (using boost on open roads).
dazz_ni45
Re: Miles to a tank
Post by dazz_ni45 »
Thanks guys. My overall journey is about 400miles so I will look for a petrol station around 200-220 miles and that should see me home.
Nails
Re: Miles to a tank
Post by Nails »
I only get between 200-240 in my rev 2 and that seems to be running ok., I'd start looking at 180 miles, you cant have too much petrol
dazz_ni45
Re: Miles to a tank
Post by dazz_ni45 »
If anyone spots a black rev 2 turbo stranded on the road between stoke-on-trent and stranraer on Friday that will most likely be me and please stop and help! :pray:
Steve-O 2007
Re: Miles to a tank
My car stinks of unburnt fuel but seems to run fine. Oh Im running a VTA DV as well which might cause it a little. Might get a timing light and check the timing, could off timing cause bad mpg?
Slarty
Re: Miles to a tank
Post by Slarty »
dazz_ni45 wrote:Thanks guys. My overall journey is about 400miles so I will look for a petrol station around 200-220 miles and that should see me home.
You should be perfectly safe following that train of thought :thumleft:
I can get 240 miles to 3/4's of a tank in my rev3 (on motorways) and have, in the past (when fitted with what I think was a VERY lean running Unichip) have managed approx. 350 miles to a tank so you should be right as rain.
SFLee
Re: Miles to a tank
Post by SFLee »
you can alway bring a spare petrol can
when it does run out, fill it in turn on tomtom and start look for a petrol station :mrgreen:
mattcambs
Re: Miles to a tank
Post by mattcambs »
Rev1/2 engines can run badly and overfuel with VTA DVs as the AFM is situated in front of the DV meters air that eventually doesn't actually end up in the cylinders, but vented to atmos instead. The ECU fuels for a certain amount of air, but less actually goes into the engine - therefore the mixture is rich.
Rev3/4/5 use MAP sensors at the intake manifold (after the DV) so the ECU knows the exact amount of air going into the engine regardless of where unwanted boost is vented to.
Steve-O 2007
Re: Miles to a tank
yea, but I like the noise so can live with the overfuling problem :)
mattcambs
Re: Miles to a tank
Post by mattcambs »
Steve-O 2007 wrote:yea, but I like the noise so can live with the overfuling problem :)
hope you don't mind a bit of bore wash :thumleft:
RobCrezz
Re: Miles to a tank
Post by RobCrezz »
Erm, its not a good idea really. If you like the noise get one of them HKS SSQV ones that can recirc.
dazz_ni45
Re: Miles to a tank
Post by dazz_ni45 »
Well I got home safe and sound. Had a great drive to Stranraer and the car never put a foot wrong nor did I run out of petrol!
Thanks guys
MrSix
Re: Miles to a tank
Post by MrSix »
Jeez, I have a Rev3 N/A and I'm consistantly getting 200-230 miles to a full tank. I don't consider myself a fast driver either....
Goto10
Re: Miles to a tank
Post by Goto10 »
MrSix wrote:Jeez, I have a Rev3 N/A and I'm consistantly getting 200-230 miles to a full tank. I don't consider myself a fast driver either....
Ouch, that's no better than my modified rev3 tubby! I'd give it a service if I were you!
