So driving to work, all cosy and warm in my car.
I left it idle, while i popped the lid, engine was running so rough, jerking and stuttering.
Has anyone got any clues?
Deezee wrote:OK, kinda long, but I wanna be as helpful as I can with information.
So driving to work, all cosy and warm in my car.Pull out from the lights after 10 mins of driving and the car starts stuttering and running well rough, like I'm pulling off from the lights in 5th, not 1st.
The engine would rev but there was no power.
I crawled off the road into a car park.
I left it idle, while i popped the lid, engine was running so rough, jerking and stuttering.But after 5 mins, back fine again.
Continued driving to my meeting OK.
Driving back same thing.
Started out fine then after 5 mins, it lost power, and was running well rough.
When I brought the engine to 3000rpm, and the turbo kicked in, it ran super rough.
Almost misfiring.
I checked the ECU codes, and it has none??? just blinks at a nice steady rate.
I'm thinking fuel starvation or something?
(1994 3SGTE, Apexi induction kit and Berk decat, otherwise standard)
Deezee wrote:OK, so I used the BGB as a reference and checked the resistance of the ECU Coolant Sensor, when cold and when warm, and the readings are as the book.![]()
So we can rule out the sensor.
Its feeding the signal to the ECU as well, cos pulling the connector off nearly stalls the engine when cold.
What about the O2 sensor?I unplugged that, and it had no effect to how the engine ran?
Deezee wrote:O2 sensor shouldn't cause the engine to misfire should it?Or loose power.
