wet floors
roadwolf
Re: wet floors
Post by roadwolf »
Thanks for the input, heater not leaking, just the rest of the car. :thumleft: :thumleft:
weasilfreak
Re: wet floors
Post by weasilfreak »
seals not fitted - will post back on whether they work or not. £131 from toyota, not bad i thought!
weasilfreak
Re: wet floors
ok. my last didnt make any sense - too many beers! Seals are fitted and will check if the car is water tight or not!
Quigonjay
Re: wet floors
Post by Quigonjay »
i have dry floors \:D/
HighwayStar
Re: wet floors
Post by HighwayStar »
Good job mate. Me likewise. Still have an adjustment issue with the o/s window... getting a little wind noise, but I reckon playing a bit more with the eccentric guides will sort that. Also noticed less noise too now there's a snug fit again. Fewer squeeks and a rattle has gone as well.
R.
Quigonjay
Re: wet floors
Post by Quigonjay »
maybe the door/glass needs adjustment like mine did
with the new seals pushing the door out a little bit more there is now a small gap between the glass and the b pillar rubber
HighwayStar
Re: wet floors
Yeah, it's just a question of adjusting glass and t -top till it's perfect. Fiddly though isn't it?
R
Quigonjay
Re: wet floors
Post by Quigonjay »
yep, i got peter to do mine :mrgreen:
HighwayStar
Re: wet floors
My thanks go to Luke of course. Showed care knowledge and attention ...as usual. :thumleft:
R.
weasilfreak
Re: wet floors
mine is dry like the proverbial bone now! Only one problem though - I fitted a new seal on the glass tbar and it doesnt seem to sit down far enough on the car so that the t bar seal is higher than the A and B pillar seals and there is a gap between the roof and the window now. i cant adjust the window as it fits perfectly with the A and B pillar seals and these would stop it rising any further - what should i do?
Al
HighwayStar
Re: wet floors
Get the eccentric guides from Mr T, fit the one side and pull the t-top down. Both sides cost me about £12 if I recall correctly.
R.
weasilfreak
Re: wet floors
i asked my dealership how much the eccentric rods cost and they told me it was £70+VAT!! Do you have part numbers for them as they must have quoted me for the wrong thing!!
Al
HighwayStar
Re: wet floors
Sorry no, but I'm sure somebody will be along... :thumleft:
R.
zd210
Re: wet floors
Post by zd210 »
damn! well after some more of this crappy weather I've discovered that my car seems nicely sealed when parked up, but when moving in heavy rain it seems to drip at the back of the window down onto your shoulder.
It's something I'm going to have to watch but not a major on my list for the time being. I'll just leave the coat to soak it up.
weasilfreak
Re: wet floors
i had this too after replacing the roof seal - if you replace the one on the tbar glass itself, it seems to cure it.
