[Mk2] [Turbo] Boost problem
neilgam1
Post by neilgam1 »
Hi have a boost problem.When car heats up it still boosts the same as when cold and idles about 1000-1100rpm. If you let the car idle for a minute or two the car will then boost full. Any ideas wat could be wrong?
raptor95GTS
Re: [Mk2] [Turbo] Boost problem
Post by raptor95GTS »
what's the coolant temp guage doing when you are having this issue?
Peter Gidden
Post by Peter Gidden »
Could be faulty ECU water temp sensor, which is separate to your temp gauge sensor.
Race Idiot
Post by Race Idiot »
Peter Gidden - SBITS wrote:Could be faulty ECU water temp sensor, which is separate to your temp gauge sensor.
Do you know the part number for this? I'm having problems with cold starting atm and I want to replace this to see if it fixes the problem. rev2 motor
neilgam1
Post by neilgam1 »
allan welsh wrote:what's the coolant temp guage doing when you are having this issue?
The temp gauge is half way when having the problem.
neilgam1
Post by neilgam1 »
Will try the water temp sensor first and see what way it goes.
Cheers.
RobCrezz
Post by RobCrezz »
Have a look on camskill, they are pretty cheap.
neilgam1
Post by neilgam1 »
If you go to your local motor factors and give the this quinton hazell no this is what you need XEMS37 its about 8.00 +vat.
klx_boy
Post by klx_boy »
Hey just info purposes as im going to be replacing some of my sensors soon, where is the water temp sensor located?
Cheers, Scott. :mrgreen:
