No its not been rolling roaded.
I know becuase i work with the guy.
It only has a cat back pro speed exhaust which wont do much.
I removed the rocker cover and had a look, nothing seems out all as it should be and then rattled everything else with no result.
I think it maybe the water pump as on closer inspection the sound does appear to be coming from it, but a bit hard to single it out exactly.
The rattle rises with revs but not in time with the revs, so pretty much ruled out it being an engine fault.
How much trouble would i be in if the water pump failed? Just overheat?
