Thanks in advance,
Chris
cantfindausername wrote:You could run any amount of HP on the standard brakes.![]()
The car isn't going to be going any faster is it? And the weight difference between stock and xHP is negligable.![]()
Its just gonna have the ability to get up to speed quicker.
Heat, not Horse power is what will make your brakes feel inadequate.As long as you keep them within operating temps you'll not have any problems.
jdbecks wrote:drilled and grooved discs will help slow down brake fade
Rowland wrote:Carbotech XP10s are where it's at- Awesome truly awesome fade free braking.
(When accompanied by braided hoses and a nice new set of stock discs)
allan welsh wrote:jdbecks wrote:drilled and grooved discs will help slow down brake fade
and reduce pad life and likely crack when you need them the most- plain discs work better
jdbecks wrote:allan welsh wrote:jdbecks wrote:drilled and grooved discs will help slow down brake fade
everything has pros and cons, I'm changing mine to grooved and drilled![]()
but if your building a 400bhp car having pads that wear down faster should not be a big issue, when it comes to cost and maintaining your car,
mm I should have written that better.Drilled discs are very prone to cracking, how much of an improvement they provide is also debatable
(sp).
As you say everything has pro's and cons
(sp).
