Did you have to cut the rear loop tow next to the exhaust exit?
The exhaust wasn't a perfect fit
It all looks well and tight though
Steve-O 2007 wrote:Yea I just cut that eye off incase of vibrations.Im not going to be towing anybody so dont need it and if I need towed I get towed from the front towing eye
Mine didnt line up too bad with the Flexi but maybe sw20paul adjusted one of the brackets slightly to make it a better fit? either way the flexi is deisgned to flex so should be fine
Are your exhaust tips perfectly round or does the pass side one have a slight dent in the top?
stand at your rear bumper and look straight down, does your drivers side pipe stick out about 1 inch further than the pass side?? Mine doesbut you dont notice it unless you do that
Pirate wrote:![]()
From what i've read isn't it supposed to get louder as the carbon builds up over time in the exhaust?
