How much was your respray if you dont mind me asking?
SuperRedMR2 wrote:Looks gorgeous mate! I like red cars again now!
firstmk1 wrote:Some good work there, Tommy.![]()
Now you can get to work on the engine.
firstmk1 wrote:The engine is rebuild but still lives closer to you than my car.
coverco wrote:
Rear quarters and rear screen are tinted, side windows are not, I am not going to replace the rubbing strips, I don't think it needs it, but that is just my opinion![]()
bburn13 wrote:Ahhhh-You decided to put the Tubby seats in too.
Nice
You should stick your leather ones on ebay.
I got£165 for mine and they weren`t quite as nice as yours.
If you need a set of seats for your other mk1.![]()
My SC seats are in the back yard doing nothing.![]()
Free to you Tommy.
Would give me an excuse to come and see you again
Dave
Did you tint these yourself? I've got a spare rear window I've been wanting to test tint for years but heard bad stuff about self tint- though it's a fairly easy/flat piece of glass.
I also want a silver
'SuperCharger' logo to sit centrally under the tint before I do it, which may end up looking completely horrible
(only a small logo mind).
Any tips on the tint if you did it yourself and the quality of results? I take it it wasn't that cheap/nasty foliatec/boy racer stuff you can get?
BTW I agree with you about the side strips.I think it looks cleaner and more modern without them so it's a shame to go and stick them back on again after you've paid for a respray
(IMO!)
Sharpfish wrote:Great job, i'm jealous of the result- looks stunning!
Can you tell me which MIG you bought.I was looking at the 151 clarke until I realised it needed a power pack and didn't work from the mains.
The best I can see that works from the mains is the 110E 100 amp mig.
I know it's more than enough for panels like the bodywork/arches but is it powerful enough for CHASSIS work?
(Floor pan metal and sills)
Obv i've done my own research at sites like this:
http://www.mig-welding.co.uk/forum/showthread.php?t=661
but any tips are always useful.As I will be welding outside mainly but don't want to use gas(use)less what kind of problems occur if the wind picks up? and how best to shield from the wind?
and for reference does anyone know the actual metal thickness of the different metals needing repair on mk1s? bodywork metal, sills, floorpan, inner arch/chassis/structural etc? I read somewhere than DIY migs often don't weld what they say they can(ie a 5mm can only do 3mm for example, though this can be helped with a V cut and root join but not always practicle in hard to reach areas under the car).
I'm glad to say my top windscreen area wasn't even half as bad as yours was and was solid but had rust/bubbling paint(Now fixed but needs proper painting instead of my rubbish temporary job) and i've still yet to fit a windscreen
(got to find the
# for the kit from toyota with the gasket/sponge and clips etc).
Did you rust proof all those inner arch panels before putting the top quarter/wing panel on or did you squirt waxoyl down afterwards just so I know which is the best way to do it- i've got a few pots of eastwoods rust encapsulator
(similar to por15 dunno if it's as good but it does have good reviews).
thanks in advance for any info and well done on the car..
another mk1 saved!
