![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
lockys96 wrote:christ, you really think yhr mr2 will hit 180mph!!
mr2toby wrote:This site is handy too.
Tells you your top speed in each gear![]()
http://www.catherineandken.co.uk/sti/tyres.html
2BAR Tuning wrote:
Some of the supra's i was mapping were doing 200+ mph on the gps at 8000rpm at marham mate![]()
Ryan
EarL wrote:Great stuff Marc.![]()
Richly deserved results mate.
It's a great feeling isn't it?
Nice to see the suspension off my old Beast has been put to good use on a car with equal potential.![]()
Keep it up buddy.
EarL.
3sgte wrote:Roll on 2 barEarL wrote:Great stuff Marc.![]()
Keep it up buddy.
EarL.![]()
,and possibly an inlet manifold as i think that the inlet may start to become a restriction soon
KO Racing wrote:Excellent results.![]()
It's amazing it got fitted so quickly, and I apologize about the length of time it took to ship the kit as we were moving our entire shop to a new location as of the first of the year.
I particularly like the fact that your results are some of the rarest to find where someone actually tested two turbos back to back to be able to quantify the difference.
I would be very interested in the dyno plot once you have it available.
Did anything else change on the car between the 46 trim and the GT3076R Street Brawlers
(Track Haulers!)?
As a side note, I don't recall if we did a
.7bar spring in your turbo kit or not, but it will be difficult to raise boost much beyond 22psi(1.5bar)
~ perhaps 1.6bar max
~ without having a stiffer spring in the wastegate.
.7 bar is the default value we ship the turbo kits with.
3sgte wrote:Kris could you tell me what i need to reach more boost,is it just a case of changing the spring
KO Racing wrote:3sgte wrote:Kris could you tell me what i need to reach more boost,is it just a case of changing the spring
Yes, you would simply need to change the spring in the wastegate-- but care must be taken in doing so as there is a lot of tension on it, and a diaphragm that can be pinched when reassembling.
I'd recommend removing the wastegate from the car and using a bench vise to hold it together, removing the 6 socket head screws, and then to slowly open the wastegate and remove the spring.
Then the opposite with the new spring taking care of the diaphragm and slowly re-clamp it down and reintall the socket head screws.
A 1bar spring would allow stable boost control up to a bit over 30psi of boost.
