Seems to be doing it in all gears but doesnt seem to be louder in any 1 gear, just a bit concerned any ideas?
thanks
chris
Excuse my ignorance, can you elaborate please?peoples check your exhaust manifold gaskets.
They click
Skywalker wrote:well the exhaust manifold is a multilayer metal gasket.When air starts escaping out the side it'll have a reed effect.
This will be most audible when the engine is started from cold, and as components heat and expand, it will be become less audible.
Look for black build ups around the exhaust manifold and use the diagnosis above to determine if it is indeed this gasket.
Thanks Skywalker -I know exactly what you mean, just wanted to double check with you. I checked for that before but I didn't see anything blowing on mine. The engine was only put in a few months ago as well so should be OK.Look for black build ups around the exhaust manifold and use the diagnosis above to determine if it is indeed this gasket.
