-:[KM]:- wrote:Sounded like he was doing'a rev3 transplant' to me, rather than a ECU and getting shot of the AFM.
It has already been said he could use the injectors..
not the rail on a rev2 head.
Where did you read
robsgts wrote:Hi all i will be starting my rev3 conversion soon
royashmr2 wrote:U can use ur rev2 rail.Just put the rev3 injectors in it.
Will run a lot of power on the std rev2 rail.
I have 391 at the hubs on mine.
Injectors were to small but the rail was fine.
royashmr2 wrote:robsgts wrote:cool should be ok then.
will b ok! lol
tarmac terrorist wrote:i have converted mine to a rev 3&
have no problems with reving, it went right through to 7200rpm,normally the rev problem is due to not changing the igniter on the rev 2 to a rev 3,i
greeny wrote:royashmr2 wrote:U can use ur rev2 rail.Just put the rev3 injectors in it.
Slightly OT but just had a look at your garage royashmr2![]()
What turbo you running tho?
