[Mk2] [Turbo] Fuel Rails ??
robsgts
Post by robsgts »
Hi all i will be starting my rev3 conversion soon and was wondering if the rev2 fuel rail is the same as the rev3 or is the rev3 larger inside ?
Regards Rob.
Re: [Mk2] [Turbo] Fuel Rails ??
Post by Martin F »
pretty sure the rev 3 is larger or so ive been told
robsgts
Post by robsgts »
ah so would i need a rev3 fuel rail for this conversion then ?
Rob
Post by Martin F »
dont think so...im not that familiar with the differences if your moving from one set up too another... :oops:
dai21t
Post by dai21t »
don't think the rev3 rail fits the rev1/2 inlets. you can buy bored out rails or get a wolfkatz one.
EarL
Post by EarL »
dai21t wrote:don't think the rev3 rail fits the rev1/2 inlets. you can buy bored out rails or get a wolfkatz one.
Correct. :thumleft:
You'll need to speak to either Tim (xxxx) about a WolfKatz, or Peter Gidden (sBits) for a rebored and modified ATS rail.
EarL.
-:[KM]:-
Post by -:[KM]:- »
Definately not interchangeable..
Rev3 rail is spaced differently, although the injectors are compatible.
robsgts
Post by robsgts »
could i not use my rev2 fuel rail then ?
Rob
Century Motorsport
Post by Century Motorsport »
You can use you rev 2 fuel rail with the rev 3 injectors.
If you want a nice wolfkatz rail let me know as we sell them.
Regards,
Nathan
planted1
Post by planted1 »
bought this rev 2 rail on ebay recently
(may even have been someones on here)
dual feed,overbored,with a set of rev 3 injectors :thumleft:
-:[KM]:-
Post by -:[KM]:- »
robsgts wrote:could i not use my rev2 fuel rail then ?
Rob
No.
SW20Paul
Post by SW20Paul »
Do you mean just the rev3 ecu conversion ?
If so you can fit rev3 injectors into the rev2 rail.
skipp123
Post by skipp123 »
dont mean to go off topicish... but would my sard 800s fit a hks top feed fuel rail?
Century Motorsport
If they are the side feed replacement for the std injectors then no they wont.
Regards,
Nathan
Spittinflames
Post by Spittinflames »
Rob
No.
Why cant he??...... Hicks runs a rev2 fuel rail with rev3 injectors and rev3 conversion.
-:[KM]:-
Post by -:[KM]:- »
Sounded like he was doing 'a rev3 transplant' to me, rather than a ECU and getting shot of the AFM.... :?
It has already been said he could use the injectors.... not the rail on a rev2 head.
robsgts
Post by robsgts »
Yer im doin the rev3 ecu conversion on a rev2 engine
Rob
royashmr2
Post by royashmr2 »
U can use ur rev2 rail. Just put the rev3 injectors in it. Will run a lot of power on the std rev2 rail. I have 391 at the hubs on mine. Injectors were to small but the rail was fine.
robsgts
Post by robsgts »
cool should be ok then .
royashmr2
Post by royashmr2 »
robsgts wrote:cool should be ok then .
will b ok! lol
