I will be lending my brother my car on thursday to take to his college.
What I would like information on is the best settings for completely standard suspension.
Thanks for any help
Phase One: STREET PERFORMANCE
Results: Slight decrease in ride quality, improved handling,
improved braking 10-15 hp increase.
TRD Springs
TRD Adjustable Sway bars
TRD Low pressure gas strut inserts
TRD Brake pads
TRD Brake line kit
(drain and install ford type fluid)
TRD Header and Exhaust System
High Flow Air filter
Recalibrate fuel injection system
(See Engine Preparation Section)
Reset alignment:
Camber Front:
-1 degree
Camber Rear
-1
Caster
+6
Toe in Front: 1/16 in.
Toe in rear
: 1/8
in.
Phase Two: AUTO CROSS, STREET PERFORMANCE AND ROAD RACE
(Dependent upon class restrictions)
RESULTS: Decrease in ride quality
(lowers ride height 1.5-2 in.
dramatically improved handling, improved braking.
Instead of phase one equipment:
TRD High pressure gas struts
TRD Springs
Reset Alignment:
Camber Front:
-2 degrees
Camber Rear
-1 1/2 degrees
Caster
+6 degrees
Toe in front: 1/16 in.
( 1/8 in.
out for auto cross)
Toe in rear
: 1/8
in.
( 1/16 in.
out for auto cross)
All phase one Modifications, Plus:
TRD Urethane Bushings
Front and Rear strut tower braces
Negative camber blocks
Front and Rear adjustable camber kits
Engine Modifications
( see Engine Modifications section)
Light weight fly wheel
Heavy Duty Clutch
LSD
Performance Ratio Ring and pinion Set
Close ratio transmission gear set
Soupasam wrote:Ok i'm confused now![]()
I thought that more front toe in would reduce the understeer? Can anyone clarify please
Lauren wrote:
they won't help the understeer.
Run some toe out on the front and reduce rear toe from stock settings.That ought to help.
Suspension will be tired if its original though.
Soupasam wrote:Thanks for your help Lauren and Jim![]()
As I use my MK1 as a daily driver I think i'm going to use Jims settings as a base and try them on a track.I'll be able to try the toe out settings if the toeing in isnt working for me on the track.
It's quite handy that my brothers college is based at Castle Combe circuit so i'll be able to make adjustments between sessions
Thanks again for the help
