[Mk2]16"rims tyres size combinations-any 225-45-16&245-45-16 set low?
Harry
Post by Harry »
:arrow: A...215-40-16 225-45-16
:arrow: B...225-40-15 245-45-16
:arrow: C...225-40-16 255-35-16
:arrow: D...225-45-16 245-45-15
:arrow: E...225-40-16 245-40-16
:arrow: F...205-45-16 225-45-16
:arrow: G...215-35-15 245-35-15
:arrow: TBA-NOT LISTED?
What combination do you run and or have experienced and or will fit or
and or which combo. did you not like or which do you like or prefer for
track fast road?
:D
Lezz
Re: [Mk2]16"rims tyres size combinations-any 225-45-16&245-45-16 set low?
Post by Lezz »
F - 205/45/16 - 225/45/16 on Sparco lightweight racing rims - perfect
3sgte
Post by 3sgte »
Lezz wrote:F - 205/45/16 - 225/45/16 on Sparco lightweight racing rims - perfect
as above :thumleft: had a lot of use on that setup
Harry
Post by Harry »
Had 205-50-16 & 225-45 or 50-16 on a set up i bought and the tyres were new so stayed with them-michelin pilot sport very good hard cornering
tyre good all round but not stable enough also a bit more comfort with
more sidewall flex than i am used too,that was on rays volks 16" 7&8" with
the usual 25mm odd spacers hubcentric that they came with.(No probably
not sidewall flex just more rubber per se on the higher profile-funny to
go 50 on 16's?)
A far better set up was the enkei rs evolutions using 215-40-16 & 225-45-16 7&8" wide rims with spacers too,this was a dynamic set up on tein ha
coilovers-grb451 falken tyres excellent in all departments-quiet-grainy-
grip-cornering-wear... :D
skinthespin
Post by skinthespin »
Ive run the following combinations.
F 205/55 x 16 R 225/50x16
F 205/50 x 16 R 225/50x16
F 205/45 x 16 R 225/45x16
Best copmbination for grip, feel and progressiveness is:
F 205/50x16 R 225/50x16
Don't worry too much about rolling radius, the differences are minute but the differences in feel etc are quite pronounced.
One of the most important things is to use the same type of tyre front and rear.
Harry
Post by Harry »
skinthespin wrote:Ive run the following combinations.
Yes only use the same front n rear like directional set up like grb 451/2
laser four wheel alignment-balance-set toe-camber the whole shebang \:D/
Which tyres do you use?
Hated bridgestone s02-rough-noisy-fair grip...not my bag any roads.
2Crooky
Post by 2Crooky »
I used F matey on my old rev 3 turbo :thumleft:
Loads of grip until suddenly........without warning i would be looking out the passenger side window trying to stop a spin! :shock: !!
Harry
Post by Harry »
2Crooky wrote:I used F matey on my old rev 3 turbo :thumleft:
Are they/were they the FALKEN GRB 451/452?
Why i ask this is that the name is also associated with their other model
ZIEX 512-FALKEN?
The 512 is not suitable for the bhp on tubbies and is more of a hatch back
suited tyre around the 75-100 bhp threshold...also not great in the wet.
Other factors which can influence traction as most guys do know
tyre pressure/s
camber/toe/laser alignment settings-set up
aftermarket suspension part-coilovers braces etc...
boost settings-set low in rain-general high bhp car/s
driving style-heavy foot or not or knowing when the limits are near?
traction control
aerodynamics
brkaes
road surface/s
road contamination-no rain-just rained/raining
the tyres-silica compound-hard/soft/medium compound-tread style pattern
directional-speed rating-side wall load factor-the design itself in relation to the end use..etc...
plus loads more other consideration?
:-k
2Crooky
Post by 2Crooky »
They were Bridgestone Potenza's :?
Very hard compound tyre which took ages to warm up, no grip when cold and when really pushing it once warm the grip gave up without warning! :shock:
But for that few seconds of bliss, handling like its on rails before putting me in a hedge.....they were great :lol:
Quigonjay
Post by Quigonjay »
if i had 16's i would run 205/50/16 front and 225/45 rear so i could get bridgestone potenza SO3's
EarL
Post by EarL »
Mark Edwards ran the following for TOTB 5:
225 x 45 x 16 front
245 x 45 x 16 rear
These were T1-R's.
I know, because I just found the invoice for them. :lol:
Harry
Post by Harry »
EarL wrote:Mark Edwards ran the following for TOTB 5:
225 x 45 x 16 front
245 x 45 x 16 rear
These were T1-R's.
This is my target size combination :wink:
Only thing which worries me is the front as currently have 225-35-17
and the 225-45-16 is one inch taller than the 225-35-17's(set low teins)
and want to fit 30mm spacers... :-k
poser
Post by poser »
Identical to me... except I don't think my Sparcos are up to much - I certainly doubt they're lightweight.
DavidM
Post by DavidM »
A little drift here but with option F (205/45/16 on front and 225/45/16 on rear Toyo's T1-R's) what sort of tyre pressures should you be running?
EX Caribbean Blue 10th Anniversary 1996 T-bar
EX Black 1995 mk2 GT Turbo
NOW Audi TT V6 3.2 DSG 2004 Coupe
Harry
Post by Harry »
DavidM wrote:A little drift here but with option F (205/45/16 on front and 225/45/16 on rear Toyo's T1-R's) what sort of tyre pressures should you be running?
Would go for...
town n about/ wet weather...31 front 32 rear
motorway longer distance... 32 33
speed run... 33 34
Dont waste time with the garage air pressure for tyre pressure-not accurate
Get a hand guage and check at least twice a week/long trips
I have a foot pump to fill air :lol:
tarmac terrorist
Post by tarmac terrorist »
i run 16" r32 skyline wheels
6.5j by 16 with 40 offset front (205/45/16) (with 10mm spacer) (r32 gts)
8.0j by 16 with 35 offset rear ( 225/45/16)(with 5mm spacer)(r32 gtr)
i didnt need the spacers just used them to get the wheels to run in line with the arches
Quigonjay
Post by Quigonjay »
tarmac terrorist wrote:i run 16" r32 skyline wheels
did you get those from the skyline forum?
are the front actually different to the back? cant really tell if they are the same design, ,just thought they might being from different models
Leon.
Post by Leon. »
skinthespin wrote:One of the most important things is to use the same type of tyre front and rear.
Do you mean brand or profile? I assume brand...
Harry wrote:and the 225-45-16 is one inch taller than the 225-35-17's(set low teins)
16" with 45 profile on 225 = 406.4 + [101.25 x 2] = 608.9mm
17" with 35 profile on 225 = 431.8 + [78.75 x 2] = 589.3mm
Difference = 19.6mm across the whole diameter, so radial increase is only 9.8mm, not quite so bad. Depends on your offsets as to whether you'd have to raise the suspenders a tad... I did!
tarmac terrorist
i got the fronts from rogues i think. and the backs were a pair that bry had.i got them refurbed, they are the same design but because the backs are a wider wheel they have a slight dish to them.
swuk
Post by swuk »
205/45/16,205/50/16
