Hi Folks,
I'm just in the process of fitting some Apexi N1 pro coilovers to my MR2 Turbo.
Does anyone on the forum have these fitted?
Mine have apexi top mounts, and I'm not sure which way they should face.
The four bolt configuration at the front means they could face either way
(in the left-right plane), but I'm not sure which.
It look like the original drop links will fit
(length-wise) unlike the Tein ones for example which need to be quite short.
Is this the case? I'm tempted to replace them with new ones whilst I'm doing this.
What's the best source for these?
And last of all
does anyone running these have any suggestions for settings for rd use.
I'm running 18's with 225/40's and std roll bar.
Many thanks,
Iain.
