450bhp max,minimum spool,td06 or gt3071?
Looking for a turbo to provide 450bhp max with minimum spool-up thinking about a td06 20g or gt3071r with small housing,what do you guys reckon?
Re: 450bhp max,minimum spool,td06 or gt3071?
GT3071R IMHO
- TD06 may struggle to get 450 without running high boost.
Sorry to hijack this but the GT3071r will be avalible with my new turbo kits.
Tim
xxxx
Tim
xxxx
alright tim when will your turbo kits be available? do you have any prototype pics or that yet? what turbo is it mark is goin for the above mentioned
well just need a manifold adaptor for the kits and i'm ready to go.
The small Turbo range using a manifold adaptor will use around 8 different turbo's all around the same price, the a GT30+ range using a full tubular manifold.
Don't know on prices yet but they will be competitive as always.
Just getting held up with getting a manifold adaptor made up for prototype.
I've got some pics but don't know how to host then
Tim
xxxx
Tim
xxxx
Do you think a td06 20g will outspool a gt3071r
,i want something with minimum spool so was looking at the small housing gt30's.I have a built 2.0 engine.
I am running a GT3071 with a 0.86 exhaust housing and it spools pretty well, its well on boost by 4000rpm and thats just on the actuator.
Once dave tinkers with the motec map I would expect it to be a little earlier.
Interestingly if you keep it above 4k rpm its just as responsive as the GT28 was, I was expecting to notice more lag, but its just not there.
An absolutely amazing turbo!
I cant compare to the TD06 though since I have never been in a car with one fitted.
Neil.
Neil.
Forever Feels Like Home, Sitting All Alone Inside Your Head.
hi neil,
Interesting stuff mate,any reason why you went with the
.86 housing i assume thats good for 450bhp.Do you think the
.64 would be good enough for 450bhp.
http://www.turbobygarrett.com/turbobyga ... _sheet.htm
Garatt only quote a few bhp between the two
Would really help if you had any dyno graphs etc.
neil which version you got on yours the one with the T25 or T3 Footprint?
Not that it should make much difference but i'm going to be using the t25 footprint to go upto the manifold adaptors, will an external wastegate optional upgrade avalible.
Don't see why i can't use the t3 foorprint for when i do the tubular manifold kits for the GT30 and GT35r
(sorry old terms there)
Tim
xxxx
Tim
xxxx
ryan_s3 wrote:hi neil,
I dont have any dyno plots yet since its not mapped and its only running a smidge over 1 bar.
We went for the 0.86 exhaust housing to improve boost control and keep the internal wastegate.
Neil.
how do you find boost controller with the internal gate?
Tim
xxxx
Tim
xxxx
ok neil,let me know how you get on with it once up turn the wick up.
xxxx wrote:how do you find boost controller with the internal gate?
Tim
xxxx
I dont know yet to be honest, the current map is for the GT28 running 1.9 bar and im nervous to even try it out in case anything bad happens!
Its currently running 1.15 bar on a 1.2 bar actuator and its doing exactly what it should do.
Still only likely to wind her up to 1.6 bar for the early part of the year
Neil.
yeah i understand bud, don't seem to be having much luck with that car.
well i have no doubt you'll make the power buddy, good luck in the future.
Tim
xxxx
Tim
xxxx
