A used Mongoose is the go-to suggestion usually for good reason
- they are well made, they look decent, and they sound decent.
The Blueflame is of similar quality but has different tips.
Generally not as popular as the Mongoose and therefore can be found cheaper.
One that often gets overlooked as they are quite unusual is the Janspeed
(not JAPspeed) exhaust.
It's very civilised at partial throttle and only gets noisy at WOT.
It's one of two exhausts
(well 3 if you count stock) I have for mine.
They don't seem to come up for sale very often, I've seen a few cars for sale with one on though so they are around.
Japspeed is another option.
Personally I'm not a fan of it on an NA
- too noisy.
You also cannot run a catalytic converter with it.
The custom option isn't a bad way to go as you can specify what tips you want and how you want it to sound.
Just make sure that they retain your stock downpipe flange
- this means you can easily fit a stock one
(or another aftermarket) again at a later date if needed.
