In a week or 2 will be fitting the new engine and have changed my mind on intercooling.
Have been reading as much as possible and think I've got a handle on the entire setup save for one detail.
Some people seem to be happy with the results of a small 310x115x113mm core with decent pump and rad.
Is the 75% larger core really needed for a target 300hp setup?
Or am I being short sighted by trying to reduce the weight and packaging using a small core?
Setup is gen 4 engine, ct15b turbo, about 17/18psi boost.
Looking to use the bosch 1200L/H pump, fiat rad and 19mm hoses.
Got some nice packaging ideas, mounting the core by the firewall infront of the gearbox.
This is all using the ebay cores.
How has your set worked for you? All experiences welcome!
