so im going to replace my oil pump as a very low revs and engine warm im getting the light flicker which i know means oil pressure low!
Has anyone ever changed the oil pump?
I do not want to have to remove the engine
I now have a brand new oil pump, water pump, and belt to go on.
Im in Yeovil somerset if anyone wants to earn some good money helping me sort this. thanks
[Mk2] [Turbo] Oil pump swap - anyone done it? anyone want to help me do it!
Re: [Mk2] [Turbo] Oil pump swap - anyone done it? anyone want to help me do it!
Just a bit more info on my issue: I have replaced oil with 40/10, new oil filter, cleaned out the sump, replaced oil sensor.
so i know only thing left is the pump, which as the car is coming upto 100,000 and 22 years old is to be expected
Vampire wrote:Just a bit more info on my issue: I have replaced oil with 40/10, new oil filter, cleaned out the sump, replaced oil sensor.
I would check your big end bearing first, I am sure you are going to find them worn and that will be where your oil is going
Yeah- good call on bearing inspection, so the first thing to do is pull the sump...you'll need to do this to replace the pump anyway.
at 1000revs or above the light is off, but if it drops down below it starts to flicker.
when u say big end barings, is that something i can replace/fix while im doing the pump, as ill do all at once
Is the engine hunting, revs dropping too low? That may cause a low oil pressure situation ?
ive done the oil pump on my drive way not this summer but last summer took me about 8 hours as I couldnt rembmer how to slip the timing belt on.
its relatively easy might have some pictures when i did mine
I was silly and replaced my oil pump as it was leaking after replacing the crank seal. bit OTT but the only thing i havent rpelaced is the bottom end bearings and the piston rings everything else is like new and wanted to keep it running for years to come.
iv now ordered big end bearings aswel, i know there is 3 sizes, but iv gone for standard size and will get the additional if needed.
Thanks for the help so far guys
