Got the HSD monopros on today.
Will do a proper write up with pics in due course.
The finish is of real high quality on all components.
Adjustment is a PIA as you have to disconnect the drop link or un-bolt the lower strut bracket to make any adjustments.
Also the damping/rebound adjusters are on the bottom of the strut meaning you have to lie on the floor to reach them!
But after an hour test ride initial results aren't great! The ride is super stiff, probably equal to that of the TA technix! Driving down the dual carriage way and a surface change meant I nearly head butted the t-top.
I'm hoping it will settle down after the reccomended 100 mile bed in period after which it will be in for alignment.
If not I will have to make use of the 30 days return policy and just replace the shock inserts on the technix and put them back in.
