Intercooler
3" downpipe
ensure all ignition components are up to date
What else?
mr299ron wrote:It's called conversing/debating/talking.
rev3turbo wrote:Every few months or so it seems some muppet comes on here starting a million threads asking for advice, then ignores advice given and does what they want anyway..
which is usually always the cheapest option
Crack on
mr299ron wrote:
But im sure youre all be happy now, as im going to leave this forum and bother some other.
mr299ron wrote:
Thanks to most of you that were helpful.
mr299ron wrote:http://www.koracing.net/viewarticle.php?article=10
Look at the stage 1 and stage 2 requirements.
Mr2 Primer has also suggested similarly.![]()
This is why im giving my"own" answer.
Mugs.
mr299ron wrote:Berk Intercooler will be sufficient enough.Fueling is fine, just swapped in a new fuel filter and the stock system is good for a little more power.
Headgasket..
hmm.
people have said it'll either be fine or it won't be.
I don't rag the absolute balls off the car, and neither do you need to with the CT26, so I'm gambling on it being okay.
Thank++++ for that
you are welcome
Gee Man wrote:mr299ron wrote:Berk Intercooler will be sufficient enough.Fueling is fine, just swapped in a new fuel filter and the stock system is good for a little more power.
Headgasket..
hmm.
Yeah mate the berk will be up for the job.![]()
I'd maybe get a wideband on just to check the fueling just to be on the safe side.Might be worth throwing in an upgraded fuel pump if you'll be going for more
& more power in the long run.
I'm sure a ran 1.1 bar on an ATS ct27 on a rev2 set up and my stock fueling was fine on the wideband.
