Rev1 into rev2
Rev1 into rev2
Hi can someone tell me if the ecu's are the same in the Rev1 and rev2 please
Re: Rev1 into rev2
They are different
Re: Rev1 into rev2
In that case does anyone know were I could get one also do I have to change the wiring loom
Will a rev1 engine not work in a rev2 then without a rev1 ecu
Re: Rev1 into rev2
Hi do I need to swap the ecu when I'm just swapping the engine
Re: Rev1 into rev2
Ok, is it a REV1 Turbo or N/A engine, If its n N/A is it a UK or Import N/A engine and finally is your car an import or UK model
Re: Rev1 into rev2
Both UK na models as far as I know what would stop them from working anyway the connections on the engine
Re: Rev1 into rev2
cooperman wrote:Both UK na models as far as I know what would stop them from working anyway the connections on the engine
Just use the wiring loom and ECU off your old engine on the new one you are going to fit, easy.
