Rev1 into rev2
cooperman
Rev1 into rev2
Post by cooperman »
Hi can someone tell me if the ecu's are the same in the Rev1 and rev2 please
cooperman
Re: Rev1 into rev2
Post by cooperman »
Anyone
alanmr2turbo
Re: Rev1 into rev2
Post by alanmr2turbo »
They are different
cooperman
Re: Rev1 into rev2
Post by cooperman »
In that case does anyone know were I could get one also do I have to change the wiring loom
Will a rev1 engine not work in a rev2 then without a rev1 ecu
cooperman
Re: Rev1 into rev2
Post by cooperman »
Hi do I need to swap the ecu when I'm just swapping the engine
alanmr2turbo
Re: Rev1 into rev2
Ok, is it a REV1 Turbo or N/A engine, If its n N/A is it a UK or Import N/A engine and finally is your car an import or UK model
cooperman
Re: Rev1 into rev2
Post by cooperman »
Both UK na models as far as I know what would stop them from working anyway the connections on the engine
cooperman
Re: Rev1 into rev2
Post by cooperman »
Bump
bobhatton
Re: Rev1 into rev2
Post by bobhatton »
cooperman wrote:Both UK na models as far as I know what would stop them from working anyway the connections on the engine
Just use the wiring loom and ECU off your old engine on the new one you are going to fit, easy.
