oukie wrote:On a mk1, if your running stock power, 215 is way to wide, 195 is optimal.Even 205 will tramline, it's the offset and stud/spacing that will Hogan actual wheel sizes more.
This is just my opinion, but one that a good few mk1 owners probably share.Happy wheel hunting
Lauren wrote:I would also say 195's is plenty.I would say 7.5" is ideal for this width.
7.5" on 215s is fine, I run this size tyre but with an 8" rim on my TE37's.I do like the tyres to be a little stretched to take the slack out of the sidewalls though.
You will get some bad tramlining on an MK1 with such wide tyres though.
The MK1 steering doesn't really help in this respect as it will be pretty heavy at parking speeds.
I've recently bought(well I will when I get back from holiday) a set of Work Meister S1's for my AE86 in 7.5" which I will run 195/50's on.
