The way we approach it is to make sure that for a given line pressure, each wheel's brakes give the same
(or very close) the standard amount of torque, allowing the vast majority of people to retain the standard master cylinder and bias valve etc.
Or course if people want more front or rear bias the setup can be customised, but most don't.
The normal way this happens is as the discs get larger
(and disipate heat faster etc as a result), the pistons can get smaller, giving you a better pedal feel.
Here are a few real examples of the way the bias is affected
(I haven't got the numbers for the new/due soon Supra front disc 4-pot
/ RX8 rear disc OEM caliper setup, I can do them if you like?)
Standard Rev 1 Mk2:
![Image](http://i279.photobucket.com/albums/kk159/keri-wms/bias/SW20-R1-OEM.gif)
Standard Rev 2 Mk2:
![Image](http://i279.photobucket.com/albums/kk159/keri-wms/bias/SW20-R2-OEM.gif)
.so that's the standard cars, here are the upgraded options.
Rev 2 rear brakes matched with 298.5mm disc
/ 1.38" piston WMS kit, what most people would use I'd have thought:
![Image](http://i279.photobucket.com/albums/kk159/keri-wms/bias/SW20-R2-1_38-4P018.gif)
Rev 1 rear brakes matched with 298.5mm disc
/ 1.25" piston WMS kit, handy to know it works:
![Image](http://i279.photobucket.com/albums/kk159/keri-wms/bias/SW20-R1-1_25-4P018.gif)
-------------- the ones below don't have a handbrake
(WMS 4 pot front and rear) so are full-race only
Maintains bais, might have a soft pedal:
![Image](http://i279.photobucket.com/albums/kk159/keri-wms/bias/SW20-1_75-4P018-1_38-rear.gif)
Increases front bias, medium pedal:
![Image](http://i279.photobucket.com/albums/kk159/keri-wms/bias/SW20-1_75-4P018-1_25-rear.gif)
Increases rear bias, best pedal:
![Image](http://i279.photobucket.com/albums/kk159/keri-wms/bias/SW20-1_38-4P018-1_25-rear.gif)
