It goes pretty well as you would expect, not in the same league as the Mk1 3s-gte conversions or V6 versions torque wise but a quick little car all the same, however i fancy having a proper go at a reliable 4a-gte, the Woodsport way, it's an itch i've been dieing to scratch.
I have a spare 4a-gze engine so no need to touch the current SC install, meaning if things don't go entirely to plan i can fall back onto the SC motor.
The plan is to run a T25, on a Woodsport exhaust manifold
Management will be stock gze injectors and ECU
I will also mate this to one of our 6 speed gearbox conversions instead of the SC box, the emphasis on this project will be weight saving with lots of power.
The engine itself will get a full rebuild, MLS gasket, ARP bolts and will run a 16v intake plenum
Anyway, that's the project, most of you who know my build threads will know you're in for a pretty good write up, so hopefully it will help others, it won't be as groundbreaking or mad as the other stuff we've done, but an excercise in doing it right.
That's the plan anyway!
