But while at it I had a UK rear fog light switch that I wanted to swap out for an aftermarket type.
The aftermarket rear fog light switch has 3 wires, one is wired to the ignition, one is bridged with the front fog switch and the last goes to the rear fog light.
The UK rear switch has 4 wires but essentially it looks like 3.
Anyway I unplugged the aftermarket rear fog switch and temporarily wired the UK rear switch.
It worked perfect even glowed green when on.
Next I had to strip the rear fog switch wires of their clips, that's when I got a spark and I lost:
Park/Side Lights
Front Fogs
Rear Fog
Tail Lights
But I still have:
Dipped/Main
All Turn Signals
Brake
Reverse
I checked the fuses but all were ok especially the Front Fog.
Really not sure WTF happened.
I must mention, I did work on it with the ignition was on.
Anyway need help/advise on what could have happened.
I had the switch off many times before without issues but this time it didn't like it.
If you require more info on the car I will post.
