Gen1
2mad wrote:This engine bay pic's quite helpful.
http://www.mr2oc.co.uk/ku2/mk2engineloc ... gine01.jpg
Those two ports are for the map sensor(you know now) and fuel pressure regulator
(make sure this is hooked up).
Good luck mate![]()
Ps.if the car fires up then dies 5 to 10seconds later, this can sometimes mean you have a leak between the air flow meter and turbo
or you have totaly over looked something like an un pluged sensor
(done this myself
ProGeoffrey wrote:the coolant temp sensor came apart
Peter Gidden - SBITS wrote:ProGeoffrey wrote:the coolant temp sensor came apart
That's the cold start switch, not temp.sensor.
ProGeoffrey wrote:Peter Gidden - SBITS wrote:ProGeoffrey wrote:the coolant temp sensor came apart
Thanks mate.Would the cold start switch not let the car idle when hot? would you know lol
2mad wrote:Dont worrie about theEGR vacuum or exhaust gas recirc
(EGR) valve, thats for the us.
Do worrie about your fuel pressure regulator, the vac line should run from manifold nipple to regulator with no t-pieces fitted
The other goes to map sensor..
A t-piece to boost gauge if you have one is fine.
The one on the side of manifold goes to blow off valve iirr..
The one or two on top or throttle boddy(rev1 or 2) just cap them off for now.
There for the charcoal canister I think
(I just had them capped off)
The two nipples on the back of the manifold I forget what there for![]()
Just to see if the car will run you could just cap them off for now.
Good luck![]()
Coolant sensor, get creative and fix that.
Ps.I'm thinking of my rev2 so the more pictures you can post the better i can help
Basically the car will run with everything capped off bar the fuel pressure regulator.
once its running you can start plugging back in
tvis, map
, bov, charcoal canister ect
Guess what- the cold start switch only works when it's cold
- and switch the 5th injector on for easier starting.
So it has nothing to do with idling and nothing to do with anything hot.
You sure mate? I dont want a guess i can do that myself.I'd prefer fact
2mad wrote:This is how you tvis system should be hooked up(from a st185)
look at were pipe 3 hooks up to theres a nipple on the runner if you did not know it was there
(i had it capped off i was not running tvis)
http://imagizer.imageshack.us/a/img801/ ... istvsv.jpg
Lol, Peter's the man![]()
he knows this
$hit back to front, I'm doing my best from 8 year old memory's.
ProGeoffrey wrote:
I dont really see how you can say that without being a dick![]()
