Having 4 cars is getting too much trouble
Bought it from RichieGTS who owned the car for 11/ 12 years.
Imported circa 2000.
Shows roughly 128k, was converted to miles when imported BUT the speedo is reading 10 mph over speed true speed it is possible that mileage is actually lower.
There is a switch behind the radio that converts the voltage signal so can be selected to MPH or KPH.
As expected the car is always warmed up and cooled down plenty.
I've only used V Power or Tesco momentum 99
It has a folder with receipts etc, RGB manual and other stuff knocking about.
Also had all the old MOT's from when it arrived in the UK.
Car has been garaged for roughly a year now, started up and pootled round the block, hasn't covered any significant miles since the last MOT.
MOT runs out October 31st.
interior wise;
Is standard apart form a nice Rev1 black roof liner.
Replaced the plastic sill trim with genuine 10th anniversary MR2 ones.
Isotta D shape wheel and Isotta alloy boss.
Has an after market head unit too.
The engine is good it's not smoking or burning through oil.
All standard except for;
Apexi induction kit
Blitz Nur Spec
HKS Type 0 turbo timer
It's had the oil changed every 6 months regardless of it being used or garaged.
Most probably is due a belt change in the near future.
Coolant flush, new thermostat
New Millers gear box oil ready to go in.
Body wise is reasonable,
The front bumper is pretty stone chipped as are the wings.
Drivers wing has a bit of a scrape just over the wheel arch, looks worse than it is.
Some slight bubbling around the windscreen.
Full amber JDM indicators and sidelights, a set of clear ones are included.
There is bubbling about 3/4 down the drivers sill
There are small hair line scratches on the boot lid.
I've tried to be honest about the overall condition it's not amazing but it's ok.
Wheel wise;
It's got a set of Advan SA3R's 16x7 front
Falken's on the front
BC coilovers LIKE NEW with new droplinks all round! I fitted them for the last MOT as front shocks were knackered.
Brand new set of EBC discs and yellow stuff pads will be included.
I know that there isn't much MOT left I have put a lot of money into it with parts that are basically like new or are new.
Collecting the car will have to be done on a weekend.
I have a few boxes of spares in the garage too that comprise of original parts and niff naff bits that may be useful.
