Blitz NUR R Exhaust with Extra Silencer
Nic
Post by Nic »
Finally got around to removing my Blitz NUR R mid pipe, ready to weld in an extra 3" stainless steel Jetex silencer. Space is limited so the silencer isn't that big but hoping it'll reduce the Db's a little.
Image Image
Nic
[email protected]
MR2 Rev 3 GT Turbo
CalMac
Re: Blitz NUR R Exhaust with Extra Silencer
Post by CalMac »
Make sure to post a vid when finished :thumleft:
Got the Nurspec on my NA and it's a bit OTT :lol:
Nic
Post by Nic »
Silencer welded in, it'll get fitted tomorrow for testing.
Image Image
Nic
[email protected]
MR2 Rev 3 GT Turbo
Nice work mate, I'd be interested in hearing the sound difference. :thumleft:
Nic
Post by Nic »
RedMR² wrote:Nice work mate, I'd be interested in hearing the sound difference. :thumleft:
I'll try and post up a video once fitted. Not sure how much of a difference it's going to make but if it has a similar effect to a tail pipe bung (without the performance drop the bung makes) then I'll be happy.
Nic
[email protected]
MR2 Rev 3 GT Turbo
Kongaroo
Post by Kongaroo »
You should record the before/after db readings for posterity :D
I have a small Burns stainles silencer fitted in line just before my muffler. Can't remember what the db numbers were now but I do recall it was slightly lower even with such a small in line silencer. I also found fitting a bung that reduced from 4" to 3" exit also helped reduce noise slightly too but the 3" diameter was still enough to keep performance unhindered.
Nic
Post by Nic »
Kongaroo wrote:You should record the before/after db readings for posterity :D
I should have thought of that, but it's too late now to do the before video :D
I have a tail pipe bung which does take the edge off the exhaust but significantly effects the spool up and performance of the car. I'm planning on getting the car on Oulton Park later in the year hopefully the extra silencer will get me within the noise limit. If it doesn't then I'll modify the tail pipe bung so it flows better.
Nic
[email protected]
MR2 Rev 3 GT Turbo
Nic
Post by Nic »
Got the exhaust on and it's definitely lowered the sound level at tickover, however the rear exhaust flange is blowing so I'll need to sort that out before I can properly test :mad:
Nic
[email protected]
MR2 Rev 3 GT Turbo
CalMac
Post by CalMac »
You had the chance to record yet matey? :thumleft:
Keljon
Post by Keljon »
U got a link for that silencer?
Nic
Post by Nic »
Keljon wrote:U got a link for that silencer?
U457600R Round silencer box [TURBONETT] [3 inch] [stainless steel] - Dia=125mm / L=250mm
http://www.jetex.co.uk/website/custom_p ... a=3.0+inch
Nic
[email protected]
MR2 Rev 3 GT Turbo
Mikey637
Post by Mikey637 »
I think the only way this could work for my NA would be replacing the 2.25>3" decat with one of these welded in its place.
bigdave247
Post by bigdave247 »
hi nick did you have any issues with clearance issues with the sub frame?
cheers dave
Mr2z
Post by Mr2z »
Nic
Post by Nic »
bigdave247 wrote:hi nick did you have any issues with clearance issues with the sub frame?
cheers dave
Hi Dave, there's about 2-3cm clearance to the subframe and ARB, no problems with it catching anything.
Nic
[email protected]
MR2 Rev 3 GT Turbo
bigdave247
nice one cheers :)
QUOC2008
Post by QUOC2008 »
could you just modify the baffle / bung so its less restrictive to reduce noise
MR2 REV 3 TURBO 450BHP
3000GT VR4 TT 500BHP
EVO X FQ360
