Finally got around to removing my Blitz NUR R mid pipe, ready to weld in an extra 3" stainless steel Jetex silencer. Space is limited so the silencer isn't that big but hoping it'll reduce the Db's a little.
Blitz NUR R Exhaust with Extra Silencer
Re: Blitz NUR R Exhaust with Extra Silencer
Make sure to post a vid when finished
Got the Nurspec on my NA and it's a bit OTT
Nice work mate, I'd be interested in hearing the sound difference.
RedMR² wrote:Nice work mate, I'd be interested in hearing the sound difference.
I'll try and post up a video once fitted. Not sure how much of a difference it's going to make but if it has a similar effect to a tail pipe bung (without the performance drop the bung makes) then I'll be happy.
You should record the before/after db readings for posterity
I have a small Burns stainles silencer fitted in line just before my muffler. Can't remember what the db numbers were now but I do recall it was slightly lower even with such a small in line silencer. I also found fitting a bung that reduced from 4" to 3" exit also helped reduce noise slightly too but the 3" diameter was still enough to keep performance unhindered.
Kongaroo wrote:You should record the before/after db readings for posterity
I should have thought of that, but it's too late now to do the before video
I have a tail pipe bung which does take the edge off the exhaust but significantly effects the spool up and performance of the car. I'm planning on getting the car on Oulton Park later in the year hopefully the extra silencer will get me within the noise limit. If it doesn't then I'll modify the tail pipe bung so it flows better.
Got the exhaust on and it's definitely lowered the sound level at tickover, however the rear exhaust flange is blowing so I'll need to sort that out before I can properly test
You had the chance to record yet matey?
U got a link for that silencer?
Keljon wrote:U got a link for that silencer?
U457600R Round silencer box [TURBONETT] [3 inch] [stainless steel] - Dia=125mm / L=250mm
http://www.jetex.co.uk/website/custom_p ... a=3.0+inch
I think the only way this could work for my NA would be replacing the 2.25>3" decat with one of these welded in its place.
hi nick did you have any issues with clearance issues with the sub frame?
cheers dave
cheers dave
Nic wrote:Silencer welded in, it'll get fitted tomorrow for testing.
Image Replaced With URL For Quote [url]http://url825.imageshack.us/url825/5088/57l6.jpg[/URL] Image Replaced With URL For Quote [url]http://url571.imageshack.us/url571/4085/axz7.jpg[/URL]
Looking great bud
bigdave247 wrote:hi nick did you have any issues with clearance issues with the sub frame?
cheers dave
Hi Dave, there's about 2-3cm clearance to the subframe and ARB, no problems with it catching anything.
nice one cheers
could you just modify the baffle / bung so its less restrictive to reduce noise
MR2 REV 3 TURBO 450BHP
3000GT VR4 TT 500BHP
EVO X FQ360
EVO X FQ360
