As you might know im rebuilding my rev2 3sge.
So far theres not much rev2 left, i have a rev4 or 5 block, rev3 cams and a rev2 head, i also have cunningly made the rev3 inlet manifold fit and ported the head to suit.
So now what do i do about the ecu? I have a unichip that i got of ebay, do i get this fitted and use the stock rev2 ecu and mapped or do i change to the rev3 ecu and loom and fit the unichip too?
I'll be fitting a powerdeck and have a 4 branch ss manifold and induction kit, the blocks been rebuilt with new bearings, mains and big ends and new rings.
Oh i have the rev3 injectors too
If i do go for the rev3 ecu and loom do i need the passengers side loom as well or can i just repin?
Would an adjustable fuel pressure regulator be worth it too? I was planing to use the rev3 one
Adz
