1.
2.
3.
As I was swapping my single DIN radio from my old car, but when trying to install it, it would not fit.
Thanks in advance
ElvisRockVinyl wrote:Look at you idle valve mate, sounds like it dirty, I've seen this on a few honda's, make sure all you vacuum lines are hooked up too.
I thought it'd be the ICV, i'm going to do it next week when i've got a bit more time.
For the time being i've adjusted the idle screw so it idles at 1250rpm, but it's smoother.
2, Make sure your window is closing fully, I assume your door line matches up to the rest of body when you shut it as sometimes if the door hinges are worn or not correctly adjusted then it will be to low and cause window seating problems.
It appears the window is closing fully as the window is flush with the triangle rubber at the front of the door, near the mirror when all the way up.
This seems like it needs more investigation as I jet washed it last night and the door cards on both sides were wet
3.regards the space under the radio you need a din cover that is made for the mr2 as the space is just shy of a full double din space so a standard spacer filler wont fit, I do have a genuine pocket with brackets that I took out off mine when I fitted turbo gauges in my center console above the radio if you want it as Ill only chuck it out
it's okay, I've managed to get it too fit now, using the spacer at the bottom and it overlaps the lip of the dash.I had to make cut-outs so the dash clicked back fully though.
I've since ordered a pocket with cup holders as I've only realised how much I needed them! Thanks for the offer though
