Cheers Fred
fred130111 wrote:Ahh ok cheers would that be the thing the linkages attach to?
Johnr32 wrote:Sorry to sound so noobie but what brass cube are we talking about? Where can I find this? On the gearbox side or on the gear stick side? Really want to do this on my 2 as I have some slight play too.
mrturbotom wrote:Johnr32 wrote:Sorry to sound so noobie but what brass cube are we talking about? Where can I find this? On the gearbox side or on the gear stick side? Really want to do this on my 2 as I have some slight play too.
Gearbox end, between the lever and the box
fred130111 wrote:Mine was a pain to do but only because i had no idea what i was trying to find
There are two levers attached to the gearbox, the overlap each other( if you pull one the other moves slightly
The Nut that i undid was located on the one further left which was hidden by some sort of rubber cover, undo that then it should slide down but do it slowly because my"cube" launched itself across my garage
Oh and the cube literally rests on top of the leaver with some sort of pin to hold it in
( sorry i didn't take any images
