Could this work as a replacement for a stock engine with all bolt on mods done.
I removed my engine recently and decided to do the hose from hell oil and water pump when i took the head off the gasket was a steel item but quite thick and multi
The Car ran quite well before i did all these bits thoughts could it work with out too much negative effect i think yes it would work but on the negative side is it only if boost is turned up where the problem comes in.
