Anyways I heard the rules have changed in April????
My MOT is in 2 hours
Peter Gidden - SBITS wrote:The emissions regs.have not changed so still a non-CAT test.
However, there is a new rule saying that if the car had a cat when manufactured, it must be present for the MOT..
HOWEVER, since the car is not on VOSA's database, how does the tester know whether it had a cat when built?He doesn't, and he must give benefit of doubt in favour of the casr owner.
So, bottom line- nothing has changed.
shabz wrote:problem is I just called the MOT tester and he's being a bit of a knob lol
the bit I never get over with this, is the very simple request for form VT12.
Its the appeals form.
Basically, if the tester can't be ar$ed to do his job correctly, as for form VT12.You'll pay another test fee, only this time, VOSA does the inspection.
If found to be fine, you're refunded, certified and the tester gets his ar$e royally roasted by VOSA.
Now, normally, the moment you ask for the VT12 form, testers become suddenly become a whole lot more receptive, because VOSA have the power to shut down a test station with immediate effect.![]()
Peter Gidden - SBITS wrote:shabz wrote:problem is I just called the MOT tester and he's being a bit of a knob lol
Find one that isn't a knob????
toxo wrote:Did you get that from Jiff Lemon by any chance?He is always first to suggest that whenever I whinge about MOT testers!
Harold wrote:How do you make a double post but 24 hours apart?
MR2 Rich wrote:Harold wrote:How do you make a double post but 24 hours apart?
Because it was such a good post he wanted to post it twice?![]()
