blitz access ecu
blitz access ecu
Now im aware this will open a big can of worms, but does anyone use one? im not sure whether to go for one or get stand alone.![](./images/smilies/spacer.gif)
Mr2 Rev1 tubby
http://www.imoc.co.uk/forums/garage.php ... e&CID=4217
my build thread
my build thread
Re: blitz access ecu
4ndee wrote:Now im aware this will open a big can of worms, but does anyone use one? im not sure whether to go for one or get stand alone.
You only need to go with a stand alone ECU when you need to fit bigger injectors
im not sure if i want to go big power yet, i am intending on keeping the car some time but cant decide.![](./images/smilies/spacer.gif)
As far as i am aware the blitz ecu removes fuel cut and raises boost to 17psi? and has more aggressiveness map and timing?
I cannot seem to find out if its good or not, i can get one cheap but some people say there awsome and some say there rubbish
Mr2 Rev1 tubby
my build thread
my build thread
I to am looking in to this so I can aim for bigger power but who maps these as I've come from vag and a scooby so the stand alone ecu is mapable.![](./images/smilies/spacer.gif)
there not mappable they are pre programmed maps
Mr2 Rev1 tubby
my build thread
my build thread
Ok so how does these work then if you don't mind me asking? Do you need certain mods for the maps to work or do you just plug it in and it learns what you have and maps accordingly? Sorry for the questions but this is a learning curve for me.![](./images/smilies/spacer.gif)
They may have been mapped to specific cars with specific mods, you would probably get similar results using boost controller on a standard ecu.
if i had a mr2 i wouldn't want to be putting an ecu on my pride and joy with an unknown map on it.
![Think :-k](./images/smilies/eusa_think.gif)
i was under the impression they were all the same maps only differ on revisions.
Surely as its not mapable its just a chip
Mr2 Rev1 tubby
my build thread
my build thread
4ndee wrote:i was under the impression they were all the same maps only differ on revisions.Surely as its not mapable its just a chip
It may not be mappable as such but it is running an unknown map from somewhere, if they are all the same then what mods did they use for the original base map
- IMOC Moderator
They are mapped for a car with breathing mods, mapped for up to 22psi, rev limit raised, speed limiter removed and fuel cut removed, they are pretty good for what they are, plenty gains over the stock ecu, although this is a daughterboard attached to a stock ecu.
I run one on my car, it's great
thats what i suspected they are set up for a car with air filter exhaust and de cat i.e basic mods
Mr2 Rev1 tubby
my build thread
my build thread
