bobhatton wrote:The car is used for sprints and I can only get 265 tyres on the rear.It will have anything from 650 to 1200 HP, and the max revs will be around 9000.
The main problem with any two wheel drive car is getting the power to the ground so by bringing in the boost later I hope to stop a lot of the wheel spin.
ashman wrote:The wheel are already turning once you're at 3.5k rpm, so less likely to spin than when ramming home loads of torque from a standstill I guess.
1200 horses from 2.2 litres..
.a fekin huge turbo, lots of revs and race fuel
