Front tyre sizes, max width on 17's?
RyanRs
Post by RyanRs »
Does anyone know whats the widest tyre i can fit up front on a 17" wheel, without altering the arches?
thanks
Tsia
Re: Front tyre sizes, max width on 17's?
Post by Tsia »
I think we'll need a bit more info than that! i.e the specifications of the rims! :)
raptor95GTS
Post by raptor95GTS »
also suspension setup, lowered, coilovers? All makes a difference.
bobhatton
Post by bobhatton »
You do not need anything wider than a 225, just use a good tyre
raptor95GTS
bobhatton wrote:You do not need anything wider than a 225, just use a good tyre
sadly there isn't much for 17's on 225 that fit the front of MR2's :( 225x45 wont fit stock suspension without some er modifcation to the spring cup
synXero
Post by synXero »
You don't get much understeer at all from 215 fronts. I guess it all comes down to front-rear balance.
Nic
Post by Nic »
What width and offset are the wheels?
Nic
[email protected]
MR2 Rev 3 GT Turbo
dan4
Post by dan4 »
Im attempting a 215/45/17 on a 17x8 et35 should have trial fit next week
Magic Beans
Post by Magic Beans »
Any recommendations Bob? For a road car at least? Is it a no no to have differing makes on the front and rears?
Herts66
Tyres
Post by Herts66 »
I see nothing wrong with mixing brands front to rear.
Ideally just don't do it on the same axle.
madbasshunter
Post by madbasshunter »
dan4 wrote:Im attempting a 215/45/17 on a 17x8 et35 should have trial fit next week
Don't think they will clear the spring cups as my 215/40/17's on 8" rims are close.
madbasshunter
Repost #-o
Last edited by madbasshunter on Sun Jan 06, 2013 10:20 am, edited 1 time in total.
dan4
Post by dan4 »
This is what i thought shame il give it a go as i have a pair of 45's
Herts66
Tyres
Post by Herts66 »
17x8 215/40s here but on an ET42 offset.
Very close to the spring cup and strut body.
Kongaroo
Post by Kongaroo »
RyanRs wrote:Does anyone know whats the widest tyre i can fit up front on a 17" wheel, without altering the arches?
thanks
235/40/17 fits under the spring cup (barely) and has been done on an 8" width wheel by quite a number of people already. I've not heard/read of anyone getting wider than that on stock arches. HTH :thumleft:
alan_uk
Post by alan_uk »
i have 215/40/17 on front 8" wide et35 on tein coilovers with no problem using toyo t1-r handle well :)
cosmos
Post by cosmos »
Works with a mixture of the right offset and a lump hammer on the strut tube me thinks.
Torero
Post by Torero »
Kongaroo wrote:235/40/17 fits under the spring cup (barely) and has been done on an 8" width wheel by quite a number of people already. I've not heard/read of anyone getting wider than that on stock arches. HTH :thumleft:
Doesn't this rub on the arch liner when on full lock and full spring compression?
With a et35 offset I'd assume you'd need a 10mm spacer to fit 235s but then I'd imagine the arches would need flaring. Feel free to correct me if I'm wrong as this is what I worked out for my new rims.
3VZ-FE V6 TRD Widebody Replica
Draven wrote "TRD dude. TRD... Can see awesomness from anywhere. "
RyanRs
Post by RyanRs »
thanks
235/40 is the size i had in mind, i am using 215/45 atm with loads of clearance on an 8J rim. I just need some more grip up front to compliment the 4-pot calipers i have on there. I am considering some R1R's on the front and the rears will be r888 275/40/17 -i know these will not fit the arches however i have intent on fitting arch flares soon. suspension btw is tien ype- flex.
synXero
Post by synXero »
Original vs. 215/40/17:
215/45/17 vs. 235/40/17:
OEM is 595mm tall, so both of these are quite a long way out really. The 215/40/17 is closer to stock size but that isn't one you've chosen. Personally I'd recommend that, as my own tyre choice! :thumleft: To put it in perspective, 195/55/15s vs. 235/40/17s...
Do you really need 235mm of rubber? 235/35/17s would be only 1mm larger in total diameter, so they would be nice, but finding quality tyres that size...
