I don't mind paying for things if they are done correctly which I know they will be with the person that quoted this.
GT3076r Turbocharger Kit, External Wastegate setup
1000cc Injectors and topfeed Rail Package
SX Fuel Pressure Regualtor
New Walbro 400lt/hr Pump
Estimate
Engine rebuild labour costs
Machine Costs
Toyota Stock Parts, pumps, seals, gaskets, fluids, oil etc etc
Forged Pistons
Uprated Conrods
ARP Mains
ARP Head Stud
ARP Flywheel
Uprated Head Gasket 1.6mm+ to lower compression to low 8.
Uprated Bearing Set
Uprated Valve Springs
Adjustable Vernier Pulley Set
High Lift 264 Duration Cams
Oversized Intake and Exhaust Valves
Fidanza Flywheel
Clutch for this power
Total
Fitting into the car est 10-15hours
