Rust and The SW20
Mike
Rust and The SW20
Post by Mike »
The Rev2 yet again passed its MoT at the weekend, very pleased. However, the sills are getting pretty bad towards the rear now. They were highlighted as an advisory and the tester told me that they will almost certainly fail next year.
So, having heard snippets of rust horror stories over the years, what is the reality of rusty sills on the SW20?
Would welcome any sound words of advice and first hand experiences anyone would like to share.
ryan
Re: Rust and The SW20
Post by ryan »
alanmr2turbo
Post by alanmr2turbo »
i did my mates this year. They didnt look bad till i cut them off and then found all the inner strenghening needed doing as well.
3 days of welding and making up plates :(
Super_red
Post by Super_red »
Pretty bad like all cars this age subjected to salted roads, this was a blister the size of a 20 pence about 3 months after it passed an MoT
All the inner panels at this point were rotten through so the blister on the outside was the last thing to rot but the least important.
alanmr2turbo
arghhhhhh that brings back memories, yours are almost as bad as my mates :lol:
ryan
Post by ryan »
I wonder if theres a pattern to this tin tops Tbar, drainage points, different sill structure perhaps with Tbar chassis strengthening?
One of my MR2s went like this and it was a Tbar. I find it hard to believe that the sponge sinking within the seatbelt panel could cause such extensive rust to the inner sill. How the hell can the sponge get that wet?
Mike
Post by Mike »
So what are we talking price wise, in a worst case type scenario?
Would hate to lose my car to rust, the rest of the bodywork is in great condition for a car of its age, and the engine is still strong despite having covered nearly 130k.
No idea what I would replace it with.
Super_red
Post by Super_red »
Mine is a tin top. The sponge was soaking wet and the water comes in around the wheel arch on mine at least as the panels in that area are not sealed.
ryan
Post by ryan »
Super_red wrote:Mine is a tin top. The sponge was soaking wet and the water comes in around the wheel arch on mine at least as the panels in that area are not sealed.
Where in the wheel arch, can you take a photo, the flexi sealant stuff failed?
ryan
Post by ryan »
Mike wrote:So what are we talking price wise, in a worst case type scenario?
im sure it cost Rob (see secondary link in the link I posted ; sends you to mr2oc) £800 and the company did a great job!
Mike
Post by Mike »
Ouch, the ECU and mapping will have to wait then!
Had my trims off and had a look :shock:
Driver side:
Passenger side
:cry:
Sills are all good though, so will get that lot treated with POR :thumleft:
Doesn't look nice though [-(
Rob
Post by Rob »
Cost me £600, not £800 and yes they did an awesome job. Mine is a moonroof model, so it affects all types.
Rob wrote:Cost me £600, not £800 and yes they did an awesome job. Mine is a moonroof model, so it affects all types.
Yep, mine in the pics above is a tin top.
ryan
Post by ryan »
Thanks for your input Rob :thumleft:
Rob
Post by Rob »
No worries.
I think the problem is partly the foam, but mostly the wheel arch metal going a bit porous over the years. That is where mine first went through on the screwdriver test...
alan_uk
Post by alan_uk »
mine is a rev 5 moon roof and i had soaking wet sponges and a lot of rust had it cut out and plated resprayed stone chip coated then my skirts fitted all in cost £400 but the guy was a mate and it all started as a few little blisters :S
John145
Post by John145 »
The rear end of my 2 is fairly well rotten, doubt it'll be on the road by the next MOT :(
Marlowe
Post by Marlowe »
My rev2's pretty good in this aspect, but I'd like to keep it that way. I plan to keep it off the road in Winter for the reason Super_Red stated.
Is there any way of removing the foam to pre-empt?
Also, a side note, but If it's any consolation modern cars have the same problems - my 06 plate GTI had the common VAG fault of foam in the front arch trapping water and causing rust which lead to a warranty claim for a whole new wing (after a lot of arguing with VW UK who didn't want to honour their own warranties...). It was common across the range and I think they replaced the foam with sealant as a result - but only on 10 onward cars. :(
Rev 2 Turbo (Testing my patience)
Golf GTI MK5 (Competent but dull)
Loque
Post by Loque »
Good God this is scary reading.
