berima wrote:![]()
you sell just the ecu
RedMR² wrote:berima wrote:![]()
Sorry,'tis all as one package.
berima wrote:RedMR² wrote:berima wrote:![]()
Cheers![]()
i have all these rooms
RedMR² wrote:Ah! I see![]()
megamonkeyman wrote:I have completed this conversion.Let me know if you have any questions.
Parts swapped on my car:
Rev 3 ecu,
540cc injectors,
Intake Air temperature sensor,
Manifold Air Flow sensor,
Manifold Air Pressure sensor,
4 wire O2 sensor,
Rev 3 Ignitor,
Optional parts from rev 3:![]()
yes I need of your help.
I would like to know if you kept engine loom of rev2? and how you have make to connect up ecu rev3 on the engine loom rev2? would you have photographs s
'il please you?
CT20b turbo,
Rev 3 Cams,
Rev 3 ecu,
540cc injectors,
4 wire O2 sensor,
Rev 3 Ignitor,
CT20b turbo,
Rev 3 Cams,
megamonkeyman wrote:Yes it's the Rev 1/2 loom.![]()
I spliced the wires at the ecu.I just poked the wires into the ecu ports and connected where needed to test.
Made good later.
You can solder or use crimps.
