Pinking/spitting??
PW@Woodsport
Re: Pinking/spitting??
Post by PW@Woodsport »
These cambelts are self tensioning during fitting though... then you lock them off, how does anyone end up with an overly tight belt?
SuperRedMR2
Post by SuperRedMR2 »
james123 wrote:Right well I'm getting a the use of a timing light this weekend so I'll check it then... I've made sure the timing marks are all right so is the dizzy.. Problems are, black and white smoke coming out of exhaust, poor mpg, and there's a high pitched whine when it's running not sure wheres it's coming from tho! Other than that it runs and pulls nicely!! I can't find any leaking hoses when I had a quick look today
Is your EFI sensor still not doing anything? It'll cause your car to overfuel if its not connected/or not working.
elbon50
Post by elbon50 »
Black smoke indicates overfuel, hence poor MPG
White smoke can indicate ethelene glycol being burnt :shock:
Hope not that :!:
Peter
james123
Post by james123 »
its like a whine on tick over and almost like a hissing noise when im on the throttle...
the efi sensor works now aswell..
ive only just replaced the hg and rebuilt the head for yous that didnt know, dunno if that could help get to this annoying problem!!
james123
Post by james123 »
Update time... Noticed the little metal pipe on top of the tvis manifold had cracked... Taped it up and thats solved the poor mpg and black smoke, the whine is still there tho, tired running the engine without the belt to make sure it wasn't the alt or anything but it's still doing it I'll try the cambelt when I've got the timing light this weekend!!
SuperRedMR2
I assume you didn't run it without the belt for very long...as the belt powers the water pump....
james123
Post by james123 »
Yes it was only run for about 10 secs
aw11rally
Post by aw11rally »
PW@Woodsport wrote:These cambelts are self tensioning during fitting though... then you lock them off, how does anyone end up with an overly tight belt?
I gave it a little extra for good measure!
PW@Woodsport
Oh right, i bounce the tensioner a few times to take up any slack in the rest of the belt but always let it relax to the correct spring tension before locking it off, it's not good having it tight.
BIGBOBO
Post by BIGBOBO »
james123 wrote:Update time... Noticed the little metal pipe on top of the tvis manifold had cracked... Taped it up and thats solved the poor mpg and black smoke
Exactly what happened to me 3 years ago on a trip to southern france. Silly peugot mechanic wouldn't look at it, no toyota shop nearby so insurance towed it 500km home.
Got 2 extra days out of it + a first class train ticket home from paris. :lol:
Replaced it with a rubber hose once I got home. 8)
aw11rally
Post by aw11rally »
PW@Woodsport wrote:Oh right, i bounce the tensioner a few times to take up any slack in the rest of the belt but always let it relax to the correct spring tension before locking it off, it's not good having it tight.
I also got the inlet cam 180deg out, it was blowing flames out of the intake and for some reason wouldn't start #-o We all learn from our mistakes.
SuperRedMR2
Yeah I had that once too :oops: sounds like a gun is going off!
