Just the luck of the draw kid.
std engines have been known to crack before.
earlier rev1
& 2 blocks supposed to be stronger between cylinder walls.
(although i think it a bit of a myth really).
.more of them seem to crack around the water pump area.
Rev 5 is generally stronger between cylinder walls
(although having it x-rayed is best to check if going for big power.
) and is also revised around the water pump area for this very problem.
failing that a 5sfe block is far stronger and will cope with pretty much anything you throw at it.
(but also the most expensive option)
Some serioud decisions to made by yourself now.
![Anxious 8-[](./images/smilies/eusa_shifty.gif)
