Hello MR2 Owners
JapPower
Hello MR2 Owners
Post by JapPower »
I have a Rev 1 1990 H reg MR2, which has problems with the turbo not cooling down. With or without the turbo timer. I require a 'relay' to cool the turbo fan, anyone got one for sale? In addition, I have been told that the car uses a lot of fuel as it has been 'chipped' - which helps create the fire effect through the exhaust. I need to know how I can resolve the amount of smoke that emits from the engine, or how I am able to operate the turbo regulator and obviously not to burn so much fuel and then get rid of any smoke as it burns fuel, water & oil afterwards? I thought the head gasket had blown but thankfully that is no longer the case. Need advice please peeps.
Thank again.
kevin..in
Re: Hello MR2 Owners
Post by kevin..in »
best advice is to try the MK2 section as this is the MK1 section
PW@Woodsport
Post by PW@Woodsport »
Kev you grab his ankles, i'll hold the door open :D
